查看: 1336|回复: 5
[美国VPS] 我这样申请Vultr免费机是不是被拒了
发表于 2023-3-14 21:51:30 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Vultr 显示这个是不是被拒了。
Vultr Free Tier Program
Application Received
If you are admitted into the program, you will be notified by email as well as here.
This is a new program that we are developing and inventory is limited. Early access is not guaranteed and we will be approving accounts on a rolling basis as we continue to refine this tier. Additionally, we will only reach out if you have been accepted into the program. Ineligible applicants will not be notified.
Please note that our support team is unable to answer questions about your application status. This program is administered outside of their purview. They do not have access to the process nor do they have insight in regards to the status of individual accounts.
发表于 2023-3-14 21:52:28 | 只看该作者
translate.google.com  答案在这写着呢
发表于 2023-3-14 21:53:34 | 只看该作者
收到的申请
如果您被录取进入该计划,您将通过电子邮件以及此处获得通知。
这是一个我们正在开发的新项目,库存有限。不能保证提前访问,我们将在不断完善这一层的同时,以滚动的方式批准账户。此外,我们只会在您被接受加入该计划的情况下联系您。不合格的申请人将不会被通知。
请注意,我们的支持团队无法回答有关您申请状态的问题。该项目在其权限范围之外进行管理。他们无法访问该流程,也无法了解个人账户的状态。
发表于 2023-3-14 21:55:17 | 只看该作者
基本上吧,8号晚上申请的,到现在还这样,基本歇菜
发表于 2023-3-14 21:57:52 来自手机 | 只看该作者
信息别太假,正常号就容易过
发表于 2023-3-15 11:26:24 来自手机 | 只看该作者
tem 发表于 2023-3-14 21:57
信息别太假,正常号就容易过
意思是要填地址什么的吗
GMT+8, 2025-12-26 04:30 , Processed in 0.058286 second(s), 10 queries , Gzip On, MemCache On.
